tub diverter installation
Old 07-08-24, 08:06 AM
T
Received 9 Upvotes on 7 Posts
Hello. I got the tub diverter off finally. I unscrewed it and screwed it back on, oblivious to the fact that it has a set screw.
Not that it's off, I need to replace it. Would you please give me some pointers and perhaps link to a relevant Youtube video. The pipe you screw it on to is smooth. Please see here:
https://youtu.be/PYV79qtKUw4
The old one was probably by American standard. I wouldn't know the model number or anything.
Thanks!
Top Answer
07-08-24, 01:55 PM
Pilot Dane
Pilot Dane is offline
Received 2,326 Upvotes on 2,068 Posts
You can find videos online if needed. Make sure the pipe sticking from the wall is clean and smooth with no burrs. The new spout just slides on and you tighten the setscrew to hold it in place. Just make sure you buy the slip on style and not the NPT threaded style spout.
Old 07-08-24, 09:01 AM
P
You need a tub spout, not a diverter. You want the type of spout that slips over the pipe and is held in place with a set screw.
Old 07-08-24, 11:16 AM
T
Ok. I meant to say tub spout. Do you have a recommendation for a spout? Also, could you give me installation instructions or link to a relevant Youtube video. I think it's a smooth copper pipe.
Old 07-08-24, 01:55 PM
P
CircuitBreaker, TonySexton voted this post useful.
Old 07-08-24, 05:02 PM
T
What about the hole in the wall? Can I fill it with 100% silicone? Some said to do the top 2/3rds of it only without explanation.
Old 07-09-24, 04:53 AM
P
I caulk the spout to the wall. Normally I caulk 90% leaving a small opening at the bottom for drainage.
Old 07-09-24, 05:53 AM
T
In other words, I don't have to fill that hole?
Old 07-09-24, 05:58 AM
T
Also, please note that, after I got a new water heater installed, my pipes start rattling when I turn the shower on if the water is down too low (i.e., too cold). I was thinking that adding silicone to the space between the copper pipe and the wall would help stabilize the pipe.
Old 07-09-24, 06:53 AM
P
Rattling is usually caused by the faucet's (cartridge). A resonance can develop at certain pressures and flows.
Old 07-09-24, 08:09 AM
T
I see. I think I'm about ready to give this a try. Thanks again.
Old 07-09-24, 07:26 PM
T
Well, I have a problem. The right side of the spout was not flush with the wall for some reason. I was thinking that tightening the set screw would do the trick. Well, not only did it not make the spout tighter, it put a dent at the bottom of the copper pipe.
I'm assuming the copper pipe has to be replaced now?
Old 07-09-24, 08:59 PM
T
Is it safe to turn on the bathtub water to see if it leaks from that dent?
Old 07-09-24, 09:02 PM
T
I have to ask a separate question. When I took my new spout out of the package and pulled the diverter up, it fell down. I tried again and same result.
My old tub spout doesn't do that. That is, when I pull the diverter up, it stays up, even though it has been removed from the copper pipe.
Does this mean that they sold me a bad diverter?
Old 07-09-24, 09:34 PM
T
Here are some better looks at the dent in the pipe.
Old 07-10-24, 04:41 AM
P
The diverter is held up by water pressure. When you turn the water off it should fall on it's own. Your old one was probably sticking from years of mineral buildup.
Old 07-10-24, 05:23 AM
T
Thanks. What about that dent?
Can I turn the water on while the spout is off to see if there is a leak?
Or will the whole pipe have to be replaced?
Old 07-10-24, 05:55 AM
T
Update: I ran the water for about 5 minutes and didn't detect a leak. Is there some way to just solidify the dent? Am I good how it is? Please note that I will probably have my bathroom professionally remodeled in a couple of years, which would like include a plumbing update.
Old 07-10-24, 07:11 AM
P
The dent is caused by the set screw being overtightened but it usually doesn't hurt anything. To fix it you need to replace the pipe.
Old 07-10-24, 08:28 AM
T
I am going to cap the end of the pipe with a shark bite push cap and if the hole isn't leaking I am going to use it. I'm assuming that the water will divert to the shower head.
Old 07-10-24, 09:15 AM
P
I have never seen one of those set screw dents leak.
Tub faucets like yours are very simple. The pipe to the shower is always open to the water coming out of the valve. Normally it flows out the tub spout because that is the lowest point (gravity)(path of least resistance). When you pull the knob up it blocks the flow of water out the spout so the water rises in the piping until it reaches the next escape, the shower head. For fun, when running the tub, put your hand over the outlet of the spout to stop the water. In a few seconds the water will come out of the shower and when you remove your hand the shower will stop.
  #21
Old 07-19-24, 07:03 AM
T
I'll start here because you know the history of this job. The new spout is on. I sealed the gap between the spout and the wall with a red disc seal and silicone on the top.
The only issue is that, when I take a shower, there are two small streams of water that flow from each end of the spout head, which I bought new (Danco).
If I had to hazard a guess, I'd say that that's because one, the other, or both of these things. One, water is dripping through that dent in the pipe. Two, I put the copper pipe too short. It's very close to two inches.
To be clear, there is no water leak when the water is off.
I would like to know what you think the cause of these streams is. That said, my biggest concern is whether I have to do something about those drips. If I'm not running the risk of making matters worse, I'm inclined to just leave it like that. I plan to have the bathroom renovated in a couple of years anyway, and I'm sure that will involve plumbing of that pipe.
I cannot do anything too big on my own right now due to work constraints.
Thanks.
  #22
Old 07-19-24, 07:14 AM
P
Water should not be coming out the base of the spout. If it is it means the spout is not sealing correctly to the pipe coming from the wall. You definetely do not want any of that water getting into the wall.
  #23
Old 07-19-24, 09:16 AM
T
It's coming out of the head of the spout, not the base. There is two small streams that come down on both sides of the head when the shower is on, i.e., when the diverter is up.
It's not that I disagree, but a guy said on a Youtube video that it says on the back of the Danco spout that a little water coming from the head of the spout while the shower is on is to be expected.
  #24
Old 07-19-24, 10:30 AM
P
What is "the head"?
It is normal for a pull up type shower diverter to not seal 100%. So, if you still have water coming out of the spout when showering that is OK.
  #25
Old 07-19-24, 10:44 AM
T
The end part of the spout, i.e., the farthest part from the wall. The large opening at the end of the spout that the water flows from.
  #26
Old 07-19-24, 11:29 AM
P
Yes, it is normal for some water to leak out of there when showering. And, that's sorta a good thing. When you are done showering you can just turn the water off. Then the water in the riser to the shower head will slowly leak out the spout until the diverter falls down to the off position (and drains the rest of the water out of the piping) so you don't get sprayed on the back of the head the next time you open the faucet.
  #27
Old 07-19-24, 02:27 PM
T
That's exactly how it worked. Another DIY successfully completed with the help of this forum. Thank you!
