How to re attach arm stump?
I have a tailored sofa with rounded cushioned arms. The front of the arm has a vertical cover. That is the part that you see when you are looking at the sofa from the front, that runs from the front of the leg to the arm. I think it is called the arm stump. Anyway it seems to be attached underneath with some type of staple but it won't stay on when I push it back in. I pops off at the top and hangs there. I don't want to ruin the sofa by nailing it on. Any ideas?
Welcome to the forums! It may help if you could post a couple of pictures so we can see what you are seeing. http://www.doityourself.com/forum/el...your-post.html
