Couch pillow shape repair
Old 08-28-22, 10:16 AM
Bekrah's Avatar
Is there anyway to repair the cushions within a leather couch.
I hate the way this looks and Id rather not go out and purchase a brand new couch unless I have to.
Any advice would be appreciated.
Old 08-28-22, 10:22 AM
Marq1's Avatar
Received 950 Votes on 862 Posts
Repair what?
I see an older couch that has got marks like a pair of comfortable shoes.
Re-stuff the cushions to fuller condition, easy task, pull the leather off and get new foam!
Old 08-28-22, 10:24 AM
Received 2,957 Votes on 2,668 Posts
The leather looks to be in ok shape.
It may be time to re-stuff the cushions. Some stronger foam.
Old 08-28-22, 10:54 AM
Shadeladie's Avatar
Super Moderator
Received 305 Votes on 242 Posts
If you're doing this yourself, you want to wrap the foam with dacron to make them softer and more comfortable. The back cushions will have a different density than the seat cushions. FYI, foam is really, really pricey right now.
Old 08-28-22, 07:14 PM
Bekrah's Avatar
Thanks all.
I’d imagine that replacing the cushions will help with the wrinkles in the leather?
Also, do the cushions have to be cut to sized upon replacement? I’m not even sure where to purchase them for my specific couch.
Old 08-29-22, 12:22 AM
Marq1's Avatar
Im not even sure where to purchase them for my specific couch.
In our area we have several "Foam Factory" shops that sell nothing but foam produces!
Old 08-29-22, 04:52 AM
P
Received 1,564 Votes on 1,406 Posts
Yes, the foam must be cut to the size needed to fit your cushions. A hot wire or electric carving knife work well. Then after the foam is cut to the correct size I use spray adhesive to adhere fabric (the Dacron Shadeladie mentioned) to the outside of the cushion. This will make it "slippery" and a lot easier to stuff into the leather so it doesn't want to stick and will lay properly.
