Air pockets in vinyl floor
I had a sheet vinyl floor installed using the full adheasive method by an individual who was attemping this for the first time (big mistake). Anyway, to make a long story short. I noticed an air pocket in the middle of the floor and would like to repair it myself. I'm thinking about making an incision in the vinyl, squirt some adheasive under the buckeled area and placing something heavy on top. Will this do the trick? The rest of the floor is set pretty solid. So lifting up the flooring is not an option. Opinions anyone??
Received 0 Votes
It is probably off gassing from the adhesive. If it does not flatten out in another week pick up a seam sealer kit for your vinyl. In a discrete area of the pattern use a needle to poke a hole all the way through the flooring to squeeze the air out of. But like I said, give it another week.
Thanks to all who replied to my post. The vinyl seems to be flatening down a bit but still is not as flat as I would like. I'll give it a few more days and see what evolves. I'll try the hypo needle suggestion but I still think I'll need to inject more glue between the floor and the vinyl. Then again I'm no expert so I really don't know. I tried the hair blower trick along with an ice pack. This new Congoleum (sp??) Ultima is not very forgiving. I'll probably need a torch or heat gun to soften it up. Anyway, I'll keep you posted
Yes, a heat gun is more effective then a blow dryer!
The heat will reactivate the adhesive underneath.
That is unless there is no adhesive under there.
Injecting adhesive can be tricky. If you get too much it will fill the bubble and not have anywhere to flatten out. The lump will always be there now.
