Contact cement
Received 0 Votes
Contact cement
Would like to know if I can use contact cement on vinyl flooring sheetgood to plywood. Thankyou Bill
Received 5 Votes
YOUR TOPIC HAS BEEN MOVED:
Hello: jarhead786
Welcome to our Do-It-Yourself Web Site...
The forum I found your question in is the place in which we share Hints - Tips and Tricks. This forum is a special forum to share Hints - Tips & Tricks with other web site members and forum readers.
It is one of the 4 non interactive topics on the web site, within the NON interactive forums. Which means posting containing questions cannot get replies.
Being as that forum is NON interactive, it does not accept questions and replies cannot be posted. If your question were to remain within that forum, it would not get answered.
Since you posted a question pertaining to "Vinyl Flooring," I moved it to provide you with better service. This is the best forum I could determine to get you in touch with those that can answer your question, is in this forum.
The moderator and professionals within this forum, on the subject matter of your question, will be able to best assist you.
Regards and Good Luck.
Sharp Advice
Web Site Host & Multiple Forums Moderator.
Hello: jarhead786
Sharp Advice
Received 0 Votes
Forum Rules
Forums do not exist to favor any one product or one resolution of a problem over another. Post only information relevant to topics and avoid disputes and disagreements with others in the public formats. Avoid off the wall comments in response to those that are trying to make a legitimate response to a post.
Post your helpful information and do not challenge or make derogatory statements about others or their replies. The forums are not to be used as a venue for standup comics.
Violation of forum rules may result in your being banned.
twelvepole
Moderator
twelvepole
Moderator
Received 0 Votes
Forum Rules
twelvepole
Moderator
twelvepole
Moderator
Adhesive for vinyl
Use only manufacturer's recommended adhesive for their particular product. Otherwise, you may have discoloration, staining, and/or vinyl failure. Vinyl manufacturers are very specific about what adhesives and seam sealers should be used with the vinyl that you select. If in doubt, ask them to show you the specifications on your product as well as the recommended instructions for floor prep and underlayment, acclimation, installation procedures, adhesives, and seam sealers. If installers or you opt not to follow manufacturer's recommended installation procedures and use recommended products and procedures, warranties are invalid.
