vinyl over vinyl
Old 06-25-03, 03:50 AM
canu49
vinyl over vinyl
Stupid question, but can perimiter glued vinyl sheet be installed directly over existing full surface glued vinyl. I know the thing to do would be to put down luan or something, but I can't raise the height of the floor by very much and getting the old vinyl up looks like a real chore.
Old 06-25-03, 02:15 PM
D
Yes it can be done. You will want to use an embossing leveler to fill in the embossed pattern of the existing vinyl. If it is a smooth vinyl just go over it as long as the edges are secure.
Old 06-28-03, 09:07 AM
floorman
go ahead and emboss anyway just for insurance you don't want to take a chance of that pattern bleeding through after all that work
Old 06-28-03, 01:28 PM
Make sure you use the proper mastic for vinyl to vinyl adhersion.
If it is Armstrong, one of their interflex mastics (s-665) is labeled for this type of application, their other interflex mastic is not. Read the labels.
