vinyl sheet floor installation
Will be installing a single peice of vinyl flooring in my daughters playhouse - 6X8. The floor is made of plywood. It is dusty and dirty right now. What do I need to do to prepare the floor for the adhesive to make sure my floor is goingto stick to this wood.
Sand it? - or would that just cause a greater mess
Wash it with soap and water and let it dry?
ANy help would be appreciated
thanks
thanks
you'll need to scrape any clumps of mud or drywall mud off the floor and sweep with a fine bristled broom,then you need to put in a peice of luan or multi-ply for the vinyl to sit on nail with spot nails and patch any seams or divits in the plywood then lay vinyl
