peeling seam
peeling seam
The seam on the vinyl floor in my bathroom is pulling apart (both sides curling up). I went to Home Depot - they recommended an adhesive - I came home, pulled the floor up further to apply and rested weights on the seam. No luck!
What should I do to fix the seam? I (obviously) have no flooring experience and did not get any help from the "home improvement" store (once again).
Thanks!
Thanks!
i'm trying to figure out how you ended up with a seam in you're floor?How long has this floor been down?Regardless i don't beleive you will be able to do anything with this seam,it needed to be sealed after the floor was installed to keep this from happening,once this curling starts i don't know of a way to reverse this.I'm afraid you may end up pulling this out and starting over
The floor has been down for about 3 years. The house was rehabbed right before we moved in and we have found a few less than professional details - so I am not surprised that the floor was not installed properly. Guess we'll put it on the list of eventual improvements.
Thanks for the reply Floorman!
Received 0 Votes
Use a popsicle stick to put the glue under the curled edges, then use a blow dryer to soften the vinyl and speed up the open time for the glue. If it sticks this way find the proper seam sealer and seal the seam.The blow dryer trick usually works.
