tear in floor
Old 09-03-03, 04:25 AM
hobbs
tear in floor
Moving refrigerater out , tore small piece in floor. Have extra floor material same make and design. Are there any tips in cutting piece out and adhereing new piece to floor. Thanks Hobbs
Old 09-03-03, 07:42 AM
Jim Schnasa
Take a piece of vinyl place it on top of the area you need to repair,make sure to match the pattern.Tape it in place, so it doesn't move on you. Take a straight edge or square and cut through both pieces at the same time. Try and do this with one nice even cut on all sides. Now you should have a piece that perfectly fits. Spread the proper adhesive let it tact up the put in your piece, be very careful not to get adhesive coming up through the seams. Put the proper seam sealer on the seams and you should be set.
Old 09-04-03, 03:29 AM
hobbs
Thanks much Jim, hobbs
