Vinyl flooring in front of bath tub
Old 11-22-03, 04:25 AM
hugepinky
I am getting ready to install a new vinyl floor in my bathroom. How can I insure that the flooring will stick, and not curl in front of the tub? The sheet of vinyl is going over concreat floor. so I won't be able to add 1/4 round unless I glue it. do you have any suggestions?
Old 11-22-03, 04:43 AM
There are several makers of vinyl tub flashing.
Also called tub strip.
Old 11-22-03, 05:06 AM
hugepinky
The tub is cast iron. What is the vinyl tub strip? Will it work for cast iron?
Old 11-22-03, 01:13 PM
D
It's a piece of aluminum that is nailed to the floor before the vinyl is installed and the edge of the vinyl slips into the metal. It can't curl under a restrictive moulding.
Old 11-23-03, 04:24 AM
What I'm talking about is not aluminum. It is rubber or vinyl.
It has a peel and stick installation. The bottom of the tub needs to be clean and cleaned again with alcohol.
Old 11-24-03, 07:16 PM
T
What I've done before is purchase a piece of plastic 1/4 round moulding at Home Depot, cut it to the length of the tub and glue it at the base of the tub (to both the tub and floor). I use a panel and moulding adhesive designed for caulking guns. Works good, and looks nice too. The moulding can then be caulked around the edges and painted too, if so desired.
