vinly tile
vinly tile
I am going to install some vinly tile in a rental I have. It now has tile in it. Should I remove the old tile or just tile over it? I removed some of it in a small entry and put in ceramic there, it popped up really easy, just used a putty knife and came right up. That is my concern if I lay it over top of the old, it all coming loose. If I remove it will the old glue become a problem when laying the new? Also they are self stick tiles, I would have prefered using a mastic, but that is all they had . Can you use mastic on self stick tiles? Thanks Al
