Linolium floor (vinyl floor)HELP!!!
Old 02-22-04, 06:58 PM
Eagledriver
I just bought a new home a month ago...It has a white vinyl floor in our kitchen/foyer area...We have some clear scuffs(our son was pushing a chair back and forth on floor). I've tryed everything to remove them and there still there...Is it damaged for good or can i buff it etc...I need help or were thiniking on buying carpet because its seems to be hard to maintain...
Thanks! Eagle.
Old 02-22-04, 07:11 PM
D
Is there any extra vinyl? It can be repaired. I wouldn't try it as a DIY project, it takes some time to learn to make a decent vinyl patch.
Old 02-22-04, 07:20 PM
Eagledriver
No. There isnt any extra. I would have to buy it i guess. I was hoping it could be buff or something.I guess carpet is in order then.
Old 02-23-04, 05:58 PM
florcraft
Try lighter fluid, the same stuff to start the bar b q
don't worry, the manufacturers use it too
Old 02-23-04, 08:25 PM
D
You could maybe save the floor by cleaning the affected area with the alcohol and top coat the scratches one at a time with seam sealer.
Old 02-24-04, 12:46 PM
Eagledriver
Ok . Thanks ill try that first...
