there may be a chance for you to get some correct seam sealer and redo it, but if it is curling too much, then it is a mute point. A metal flatbar would keep it down, still using the seam sealer though for moisture.
I'm about to install about 400 square feet of Traffic Master Vinyl tile. The existing floor is old (asbestos) vinyl tile. It does have a pattern. Do I need to use an Embossing Leveler over the existing vinyl tile? I've read that it is not needed for thicker vinyl tiles (like the Traffic Master). Also, I could not find any info regarding this in the Traffic Master install documentation.
Anyone have any ideas?
If an Embossing Leveler is needed, any brand recomendations?
Thanks,
Tim
