Peel n Stick Over Concrete
Has anyone had any experience with installing Peel n stick over concrete?
I realsie the adhesive may not be strong for longterm installation, but I was looking for a quick cosmetic solution for a home that will going on the market within the next 2-3 years.
Thanks!
Thanks!
Unfortunatly by the time you get to putting the house up for sale it will more than likely be time to replace the peel and stick tile.Have you thought of sheet vinyl?
Part of the problem with vinyl tiles is the cold from the basement keeps on shrinking them and you see the gaps inbetween, and with the peel and stick since they are bottom of the line then they are twice as bad.
If you do opt for the peel and stick then i would highly reccomend using clear spread adheasive
Received 0 Votes
I'll have to say that peel and stich technoligy has improved greatly over the last two years. (I don't believe I said "peel and stick technology). I say go for it. Make sure the floor is really clean and free of contaminants.
