Vinyl Flooring
Old 06-14-04, 07:03 AM
NatalieC
Vinyl Flooring
I want to remove the vinyl flooring in the bathroom and replace with ceramic or vinyl tiles. How do I do this?
Old 06-14-04, 08:56 PM
Concrete Subfloor:
Pull the top layer of plastic up, if you can't get under the felt, on a full spread installation.
Mop the flet and adhesive that is left and let it sit for 5 minutes. then mop again and get on your knees and start scraping with a 4" wide flooring razor scraper. The wider stad up scrapers don't have the leverage needed to completely remove all the debris.
Remove all the adhesive to a clean slab.
Wood Subfloor:
Pull the " underlayment and vinyl all in one demo. Don't bother pulling the vinyl and then the underlayment. Get it all out of there in one tearout!!!
Old 06-16-04, 08:58 AM
finman
if your putting down ceramic tile, it is a good idea to use 3/4" exterior grade plywood. the most important thing about installing ceramic, is stability. you dont want the ceramic to crack
