Vinyl Floor Backing
Vinyl Floor Backing
I pulled up the carpet in my boys room to find old linoleum sheet flooring. After pulling that up a brown paper is on the floor. Do I have to pull this up too or can I lay vinyl peel-n-stick tiles directly on this?
Thanks!
Thanks!
Received 0 Votes
If it is a concrete floor use a 4" wallpaper scraper to scrape the floor clean. If it is wood install a layer of 1/4" underlayment to put the tile on. A peel and stick floor requires a VERY clean surface to advere to. Do not use any solvents to remove the felt, it will cause a bond failure with the new tile.
Thanks for your response! The paper is actually gray (not brown), is there any chance it might have asbestos? Also the paper provides a smooth surface and is on plywood and instead of the 1/4 under layment, can one use a latex primer on the gray paper then stick on the tiles?
Libby
Libby
Received 0 Votes
Don't put the tile on the felt. Perry put some good advise to remove the felt here: http://forum.doityourself.com/showthread.php?t=170534
