ceramic tile on top of vinyl?
Old 02-23-00, 08:21 AM
Guest
Question
hi,
can ceramic tile be laid on top of vinyl flooring ? i have sheet vinyl laid over concrete subfloor..........and would like to replace it with ceramic tiles,(thinset-grout). any advice?
Old 02-23-00, 03:40 PM
Guest
Post
I wouldn't lay the ceramic directly over the vinyl floor. You can either remove the existing floor or lay thin plywood over it. Make sure you seal the joints and screw heads before you lay the tiles.
Ted
Old 01-10-06, 09:03 AM
C
I currently have a handyman placing ceramic tiles over vinyl. This area is fairly small: laundry room (maybe 4ft x 6 ft). I had advised against it, but he insists this won't be a problem. I brought this up twice, but he said I am worrying for no reason. I am really confused.
