Sheet vinyl question (shrinking)
Received 0 Votes
The luan under a sheet vinyl floor was damaged by water and I was able to release the perimeter glued vinyl and replace the luan. Now as i folded the vinyl back to reglue it, it appears to have shrunk. It is about 1 inch short of the baseboard. I have quarter round to place on top but it is not wide enough to cover this gap. Will a heavy tile roller stretch the vinyl enough to cover this gap. I never imagined that the vinyl would shrink. it is still attached on 3/4 of the floor.
Thanks,
Thanks,
Received 0 Votes
What about this?? Does vinyl shrink? I bought some rolled vinyl about a week ago and I am seeing some referance to it shrinking....
How does it shrink on the roll? Wouldn't it shrink as it sits on the large roll at the store?
Perimeter glue type vinyl does shrink after it is installed.
It was supposed to float if installed over an imperfect floor. It is rolled backwards at the mill so it won't shrink before installation. Felt backed and vinyl backed don't shrink.
In addition, the installers probably did their measuring and cut the stuff outside on a warm day, and brought it back in to a cooler environment. I have seen this on many jobsites. And people wonder why I don't do soft floors.
Received 0 Votes
Rolled backwards at the mill.... meaning pattern showing on the outside?
This came from Menards... Its supposed to be left floating or glued down... I really can't imagine leaving it loose... thats called a rug.
I laid a vinyl floor from a good flooring store using the yellow glue over the whole floor. The sheet was felt backed and it has help up beautifully. Its only been 5 yrs but it looks new still.
This new sheet I have wants me to roll this contact cement type glue on the floor using a paint roller and says I can reposition it as much as need... or something to that effect. What is your opinion on this new material? Its a rental house, so whatever, but I still want a super durable surface (hence going with the sheet floor).
Just my 2¢ but we've gone to ceramic in our rentals - the upfront cost ends up being only a little bit more than vinyl but the marginal savings is pretty huge due to the significantly better durability.
It also makes it seem like the units are a little higher end, so we think the vacancy rate gets pushed downward just a touch as well.
The vinyl backed vinyl, the ones you put the pressure adhesive down with a paint roller, probably will last as long in a rental as regular vinyl . I have loose layed hundreds of yards of it with no problems. The advantage to loose laying is when replacing. You just take up the 1/4 round and roll it up. No mess.
Received 0 Votes
Thanks sam. Have you done this type using full spread (or full rolled?) glue? I have read where loose lay is ok in most rooms except the kitchin or bath room, or where there could be wheel caster furniture rolling across the floor.
In either case, I had the same 'what about future replacement' question. How difficult is it to remove the sheet later using this pressure sensitive adhesive?
