Vinyl Cove Base
Old 07-17-05, 04:48 AM
Vinyl Cove Base
What is the proper way to do inside and outside corners using vinyl cove base ?
Old 07-17-05, 11:05 AM
T
For inside corners, run the first piece squarely into the adjacent wall. Take the next piece of material and carve away the curved bottom portion so that it joins seamlessly with the first piece. For outside corners, wrap the base molding around the corner. Carve away a little of the back of the base molding so it will bend easier. Position the piece and mark the point where it will wrap. Use a square to mark the back of the molding. Bend material face-to-face and use utility knife to carve about half the of the thickness of the vinyl. The thin area will bend around the corner.
Old 07-17-05, 04:18 PM
Can't beat this for outside corners
<img src="http://www.craintools.com/vinyl_tools/233.gif"/>
Heat with a heat gun, and clamp it.
