Floor Strip Help!
Received 0 Votes
Floor Strip Help!
What is the best way to remove a vinyl floor that has been heavily glued? What are the steps I need to take to make this easy?
There is nothing easy about full spread sheet vinyl removal!!
You can rent a floor stripper machine, but your still left with glue residue to hand scrap, with a 4" razor flooring scraper, on your hands and knees.
Yes it all has to go and it is not fun. Plan on blisters.
Received 0 Votes
Hello,
Just curious why you say "it all has to go"? I am currently removing the vinyl sheet but some of the glue is still stuck on the 1/4" plywood. I am planning on putting on thinset then a Rhinoboard (backer cement board). If this is the case, would I still need to remove the last drop of glue or whatever material is still stuck on the plywood? I am hoping that i don't have to replace this 1/4" plywood that is currently sitting on top of a 3/4" Particle wood floor.
How do most professional contractors do it?
Any thoughts/comments are greatly appreciated.
Timon
LOL!!!
Your heading down a road of disaster! A complete failure!! Might as well send the money your fixing to spend, to the needy.
The problem with your situation is the particle board needs to go anyway!!!!!
