Removed Vinyl - stuck with mildew smell!
Old 10-04-05, 10:34 AM
Lolivet
Angry Removed Vinyl - stuck with mildew smell!
I removed glued vinyl sheet from my concrete slab floor in a bedroom (Lord knows why the previous owners put down sheet vinyl in a bedroom)! All the backing paper is up, to, but. there is still some glue on the floor. It smells like mildew something awful! I've tried a bleach solution and spraying Tilex all over the room to try and kill the smell, but it's not going away. The floor is dry as a bone; there is no moisture whatsoever in this room! How do I get the smell out? Any ideas?
Old 10-05-05, 07:16 PM
T
Received 2 Upvotes on 2 Posts
You might try sealing or painting the concrete floor. There may be adhesion problems if there is glue residue. Typically, bleach water solution disinfects and eliminates mold & mildew. You could also wet floor and spray floor with enzyme digester cleaner deodorizer and let set to dry. Repeat if needed.
