Vinyl Flooring under or over the Vanity and Commode?
I've stripped my bathroom of the old vinyl flooring, underlayment, base molding, commode, and vanity.
What's better - vanity on top of new underlayment and vinyl cover, or direct on subfloor?
How 'bout the toilet - on top or under the vinyl cover and underlayment?
Any special nails for the new 1/4-inch plywood underlayment?
I've heard that vinyl squares (12-inch) can slip and slide after awhile - is this true? Is this why vinyl sheeting is "better?"
Oh, and I take "steam-baths", in case it makes any difference.
All comments welcome.
Received 0 Votes
Use ring shank underlayment nails (1 1/4" or 1 1/2") - you will find these at any hardware store.
Properly installed vinyl tile shouldn't slide - this would mean the adhesive has failed. Plywood underlayment usually forms a very good bond, especially with today's vinyl tile. The big differences between vinyl tile and sheet vinyl are aesthetic - vinyl tile has seams, but it is far easier to replace a single tile.
