Go Back  DoItYourself.com Community Forums > Interior Flooring, Floor Coverings and Coatings Center > Vinyl and Linoleum Flooring
Reload this Page >
what's the minimum thickness/build-up to expect from self-leveling mortar?
Old 12-11-05, 09:11 PM
C
What's the minimum amount of rise I can expect our of self-leveling mortar?
I'm working on a boathroom that sits on the slab of my house; I'm replacing the pan of my stall shower at the moment. The new pan has a tight structural grid on the bottom so it's not forgiving of irregularities in the foundation. My thought was to pour self-leveling compound over the 36" by 36" spot where the pan will sit. I don't want to raise it too much, though, because the drain pipe is supposed to be flush with the surface. It's already there. I figured I'll be ok if it raises it no more than 1/4".
Sorry if this seems like a silly question - I've never worked with the stuff before so I haven't seen it in action.
Old 12-15-05, 06:55 AM
I have yet to see a true self leveler, that could be feather edged.
Check with the manufacturer of each product you have an eye on. The specs (on-line) should tell you where to dam, and how deep it will go.
