Help on Floor Preparation
Old 06-25-06, 07:32 PM
P
I have just taken up some saturated carpet from my old basement floor. the carpet had a mesh material underneath and then some glue on top of the concrete. I now just want to paint the floor with concrete paint. My problem is, how do I remove the leftover glue type stuff that is there now, it barely scraps off and i dont' want to spend weeks doing that. Any suggestions greatly appreciated.
Old 06-26-06, 04:31 PM
D
Received 2 Upvotes on 2 Posts
Please read the asbestos warning first and then you can try sanding it.
Old 06-26-06, 06:18 PM
P
I just didn't want to use acetone or the like cause all the warning labels tell me I will blow up my house if I use them even just a little bit wrong, I had not thought of sanding, and thats a great option, the time thing I was talking about was in sitting crosslegged with a scraper for the rest of my life. Thanks for the tip on sanding.
Old 06-28-06, 05:28 PM
T
Received 1 Upvote on 1 Post
Heat gun and scraper may be helpful. You may run into adhesion problems with paint due to glue residue in concrete. Many are going with staining of concrete.
