linoleum
Old 07-01-06, 07:47 AM
L
linoleum
My garage floor has two layers of linoleum. What can I use to get this stuff off the floor? Please help!!
Old 07-02-06, 09:25 AM
D
Received 2 Votes on 2 Posts
Are you planning on removing both layers and leave it as is (concrete)?
You will have to start with a razor and start peeling it back. Start in sections. There will probably be glue left on the concrete so you will have to scrape it or sand it.
Old 07-02-06, 09:58 AM
nap's Avatar
nap
nap is offline
New Member
Received 1 Vote on 1 Post
If it is on concrete you can rent a vibratory scraper to scrape it off.
Old 07-05-06, 05:11 PM
T
If not renting a vibrating scraper, a heat gun and hand scraper are helpful. You can cut through vinyl with utility knife and remove sections at a time.
