Particle Board prep for Vinyl Self Stick Tiles
Old 10-11-06, 11:45 AM
N
Help:
I keep hearing that you shouldn't put vinyl self-stick tile down on particle board.
Question: Does this apply to the really smooth type of particle board?
Question: If it is not that smooth, can you apply a coat of polyurethane, paint or something else to smooth it out and provide a better sticking surface?
thanks..
Old 10-11-06, 08:08 PM
G
Unhappy Bending the rules
Particle board should not be used unless specifically stated by the manufacturer of the self stick tile.
Old 10-11-06, 09:07 PM
T
Received 1 Vote on 1 Post
Do not apply to particleboard (and the warranty does not cover this).
Old 10-13-06, 11:19 AM
R
I don't have an answer for our, but I am doing the same project (vinyl over particle board). So I am also wondering what can be done to prep the surface before putting down vinyl?
Old 10-14-06, 03:55 AM
N
Vinyl Self Stick tile on Particle board
If you want to put vinyl self stick tile on particle board, what you do to prep it is to put at least 2 coats of polyurethane on it.
I just did it and it works. Make sure it is totally dry before you do it and sanding might be necessary between coats if your board is rough.
