Biogen cleaner ???
Old 10-23-06, 07:08 PM
B
Biogen cleaner ???
I have the same problem with the vinyl glue sticking, my wife ask me to try this stuff that a elevator guy gave her called Biogen works great only provlem I just had a little bit, has anyone heard of this stuff if so where can you get it. The guy is not around and she had this for years
Old 10-26-06, 11:39 AM
T
Received 1 Vote on 1 Post
It is not clear what you mean by having trouble with 'vinyl glue sticking.' Problem with removing vinyl adhesive from surface of vinyl?
Biogen Cleaner? Considering the implication of the name, it sounds like an enzyme digester cleaner. These are marketed under a variety of names such as Out, Nature's Miracle, OdoBan, and others. These are used for organic stains and odors.
If attempting to remove adhesive, there are adhesive removers available. If adhesive is water-based, soap & water & scrubbie should work. If solvent-based, mineral spirits or remover like Oops or Goo Gone would work. If enzyme cleaner (Biogen) worked, it's likely the adhesive is water-based?
