VCT Adhesive; Trowell Size
Received 0 Votes
1. What brand(s) of VCT adhesive do you recommend?
2. What's the recommended size teeth a trowell for applying the adhesive?
Thanks,
Robert
Thanks,
Robert
Received 0 Votes
I normally don't send folks to the big box stores, but, in this case, HD carries Roberts VCT glue and I really like the stuff compared to other brands. It goes down smoothly and doesn't get all stringy on the trowel. The container will tell you which trowel notch to use, but I believe it's sixteenth by sixteenth. In any case, it's a pretty small notch. I normally use Armstrong VCT, but there are other brands that work fine. Jonsonite and Tarckett are two others that come to mind.
Received 0 Votes
Thanks for the answer.
Doesn't look like local HD in my area carries Robert's, but found a tile company that does.
Robert's Website said use either 1/16" x 1/16" x 1/16" Flat Top V Notch or /16" x 1/16" x 3/32" U-Notch trowel.
Robert
Robert
