Best flooring for damp basement floor
Received 0 Votes
Hi,
I have an older home with stone walls and the concrete floor can be a bit damp in the spring and at times. I run a dehumidifier and the walls are insulated and drywalled. And the floor was carpeted but was a little musty so I removed it. I would ideally like to install linoleum and put an area rug on top of that. Would this be a good idea? Should i put anything between the floor and the linoleum? I was thinking of a sub floor but do not want to lose any height as I am 6'4" and I am almost hitting the main wood beams down there as it is.
Thanks for your ideas
Received 0 Votes
I have to agree here. If you have existing moisture problems, sheet vinyl is not a good choice for the reason already pointed out. I'm not even all that sure a built up floor will solve it alone. Getting the moisture under control would seem to me to be a better way to spend your money and efforts at this point, then worry about what to cover the floor with. That should only be a consideration after the moisture is addressed.
Received 0 Votes
Thanks guys,
The problem is that this house was built in 1880 and the nature of the stone walls and floor is that there will be dampness at times. I am thinking that ceramic tile with a small area rug would be better for this... the previous owner had carpetting and I think it was a bit musty more from the small dogs they had...
