Vinyl Tile on painted concrete?
Old 03-12-08, 01:42 AM
A
Question Vinyl Tile on painted concrete?
Hi
I'm installing vinyl tile on my basement concrete floor (the non-PEEL'N'STICK variety), but it's painted. I would like to know if I can install tile directly over the paint or do I have to strip it off. According to the manufacturer (Armstrong), I shouldn't use tile that requires adhesive over painted concrete, only their self-stick tile can go over painted floorsLink . Is it the way the glue can react with the paint? What can I do to prep the floor that permits me to do so? Also if I choose to use a floor leveler, can that be applied directly on the paint? The basement is very dry and moisture has never been an issue. Thanks.
Old 03-14-08, 01:40 PM
F
Originally Posted by AlxMAD View Post
Hi
Try to scrape it up
if it wont scrape up, try to scarify it with a sander with heavyy grit sandpaper.
then scimcoat over it with patch or a sealer to encapsulate.
if the paint lets loose, so wil lyour flooring down the road.
Old 03-14-08, 02:10 PM
A
patch or a sealer to encapsulate?
What brand/Product would u recommend? Should I get something like Levelquik, Ardex Featherfinish? Or an Embossing Leveler since its paint? Thanks for your help.
Old 03-14-08, 11:15 PM
F
ardex SD-F is fine
Old 03-18-08, 03:56 AM
A
Ardex=Henry
Would Henry Feather Finish be a good substitue for Ardex? Aren't they partnered up or the same company? Link. The reason I ask this is, my local Home Center only carries Henry Feather Finish. Thanks a lot for all the help floorman
Old 03-18-08, 08:21 PM
F
yes that's fine.
