Waterproof flooring
Received 0 Votes
Waterproof flooring
Hello!
Can someone provide honest information regarding Konecto flooring? We need to update our floors and have been told that Konecto is waterproof. We have several older dogs with urinary issues. Can anyone recommend the best type of flooring for us?
Thanks once again!
DannyD
Thanks once again!
DannyD
Hi Danny,
I don't have any personal experience with this flooring. I looked around on the web, but didn't find anything on the first page.
Try searching for consumer review or consumer report with Konecto.
I watched the video, and it looks promising, but you know...if it looks too good to be true...
Some of the pros may have an answer for you, so check back later.
Connie
Connie
I am putting down the HD Traffic Master Allure in my rental, I have read many pros and cons...and have decided that I need to just jump in and see for myself.
Good luck.
G
Good luck.
G
Last edited by Shadeladie; 04-06-08 at 04:26 PM. Reason: Removed unwarranted comments
Read your warranty. I believe that you will find that the warranty does not cover excessive moisture. One issue with planks and dog urine is that urine can penetrate gaps between planks and settle into subfloor below. Thus, trapped urine in an area that can not be cleaned. Urine odor will be most noticeable on warm, humid days.
Most pet owners tend to find that sheet vinyl works best with pets and offers easy clean up and prevention of urine pentration to subfloor. Ceramic tile is also a durable option, but grout needs to be kept sealed as it is porous and absorbent.
This something that I've always wondered...why did the laminate flooring industry move away from the glue joints to the click together? My Pergo glue together had almost invisible seams, and was very forgiving of wet mopping or snow melt. I can't believe the click type is as good at that. Also I've notice that the click together that I've seen (granted, not many), have more noticeable seams/joints.
Is it just the ease of installation?
