New Peel n Stick Popping Up
Received 0 Votes
I laid 1/4 sanded birch underlayment. I primed and let dry 20 hours. I installed peel n stick tile. I rolled it out. A week later the tile began to pop when I walk on it. Glue is probably defective. Can I simply pull up the tile and add some liquid glue to the underlayment and reinstall the tile, or do I have to remove the entire floor and sand up all the glue and start from scratch? Any other options available to me?
What you want is a pressure sevsitive adhesive. You trowel it on, let it sit and dry to a tack and then lay the tiles into it. Roll to smooth after the install. Pressure sensative floor glue is available through a flooring distributor. The big box store may carry it , but make sure it is compatable with the tile you have.
When I did my kitchen floor and bathroom floor, I just put a dab of liquid nail to each corner and on in the center of every tile and I haven't had one come up. Kitchen floor has been down 2 yrs and bathroom floor almost a yr. I did tear one up b/c of my dumba$$ dropping a knife!! Good Luck
getting old adhesive off is always best...practical? prob not..i have seen most installers just trowel the new adhesive on and let tack up...there are also additives you can add before putting the adhesive down to seal subfloor and add to the retention of the adhesive
