Flooring options for uneven concrete
Received 0 Votes
Our basement floor is flat but not level - the concrete is in good shape and is nice and dry. The problem is: it is very uneven. In some spots, there is an inch and a half difference in a span of 6' or so...
We're hoping to leave the concrete as is and install vinyl sheet flooring. Good idea? or should we focus on leveling the concrete?
Thanks for your input...
Received 0 Votes
DAP® Concrete Floor Leveler
A general-purpose, concrete-based floor leveling product for concrete and masonry surfaces. Ideal for patios, sidewalks, garages and for preparing surfaces for vinyl sheet good installation. For use with DAP®Concrete Floor Leveler Additive.
Received 0 Votes
Most floors require a FLAT surface. An inch and a half difference is not flat by any means. If it is a new pour you need to call your cement contractor back. Other than that or filling the low areas with an appropriate filler you could use a glue down type carpet. The floor will still wave back at you, but it will be covered.
