Extremely Slippery Linoleum
Received 0 Votes
I have linoleum in my bathroom which all of a sudden has become like an ice rink. i have cleaned it numerous times and have even scoured it to try and make it non-slip again. Nothing works. Does anyone have any suggestions as to what i can use on this as i am fed up of picking my son up off the floor!!!
Thanks!!!
Thanks!!!
Received 0 Votes
What are you cleaning it with? You state that all of a sudden it became slick, so what did you do that caused this? It wouldn't just do such without some help.
Is it ONLY slick when WET feet come in contact with it?
Do you use hair spray in the room, do you use a perfume spray to remove odors, or spray the shower glass door if one is in the room?
I am not picking on you.
Dale in Indy
Dale in Indy
Received 0 Votes
Me Too...
My bathroom floor has been this way. with or without socks. this is when its dry. Its new linoleum. I have used sprays for my hair. the floor has been washed and scrubbed, but it is still the same. any suggestions?
Received 0 Votes
"I have linoleum in my bathroom which all of a sudden has become like an ice rink." Floor cleaners can leave residues that make floor slick. Even if the cleaning product is one of the 'no rinse' products, rinsing is recommended to remove residues which can make floor slick, build up, soften and/or dull finish over time. Cleaners that contain wax or poly can also build up over time and make surface slick.
Hairspray overspray can build up on vinyl or linoleum floors, resulting in surface becoming slick. The lacquer in hairsprays tends to set up and can be difficult to remove.
Use a vinyl/linoleum floor stripper. Although these are sold in cleaning aisles, the best are sold at janitorial supply stores. Floor can then be sealed with vinyl floor sealer. You may want to forego any wax until son is older and more steady on his feet.
