ScottP:
A hammer and a MASONARY chisel should do the trick.
Wear safety goggles. I knew a guy that used a wood chisel for this and I still bug him about it.
Can berber carpet be installed on concrete steps...sides, top and fronts. How can you install without raw edges showing and loose threads showing and possibly running? Padding will not be used on these steps.
