vinyl cove base corners
I have some new 4" wide vinyl (not rubber) cove base, the kind that comes in 4 ft. lengths with the curved toe at the bottom. When installing, what's the best way to deal with the inside and outside 90-degree wall and cabinet corners so it ends up looking right and cleanly done. any tips/comments appreciated.
You should be able to buy matching inside and outside corners, which makes the install really nice. Otherwise, you can heat the cove with a heat gun/hair dryer and form it around the outside corners. Cut a 45+45 degree notch on the lower lip and you can press it into the inside corners. A little heat helps in the final forming if necessary.
