how do you handle right angle when installing engineered wood floor
Received 0 Votes
I am installing engineer hardwood in a hallway which in itself offers some challenges. My real issue is how to continue the flooring when the hallway had a right turn. Do I just butt the end up against the long edge or do I stagger the planks by the width of a plank? In either case how to I join the two planks to create the right angle.
Thanks for any suggestions
Bostonblackie
Bostonblackie
If I understand correctly, you would run the flooring all the same direction, continuing down the hallway with the same pattern. With 3/4" hardwood you can change direction of the flooring by using a transition strip. Not sure if you can on an engineered floor.
a transition is the easiest, however it could be considered a trip hazard, depending on the household. You can do this two different ways. One way is to continue with the direction of the wood as you take the right angle, which means you will end up with short lengths or the opposite of the other hall. The other way may not be easy, which you butt the angle into the long board or like staggering the planks like you stated, which is the same application, except you will be butting one board to one board, not eight boards to one board. BTW, sometimes laminate are not mitered for 90 degree. Try it first on sample or damaged pieces.
Good luck.
Good luck.
Received 0 Votes
Thanks for the replies that have been sent so far. The use of a transition would not work in this case which leave me with
======== or staggered layout which is fine. the problem is
l l l l l l
how to join the planks. the clips work end to end and long side to long side but not long side to end which would be the case in either layout. I do I go about connecting the planks?
BTW I now realize that I am in the wrong forum but I don't know how to move it over.
Bostonblackie
l l l l l l
Bostonblackie
what brand of laminate are you using, actually, list all information that would be helpful. And I've never used clips, so what are their purpose.
what is the size of your hall, each section separately.
Received 0 Votes
the flooring is made by Columbia flooring and it is the long strip hardwood Dales collection. The Purpose of the clips is to remove the need for gluing. the hallway is L shaped with the length of 15 feet and 36" wide the short length is 86" with a width of 39". I am installing over concrete that is level and will be installing a pad and vapor barrier.
Bostonblackie
Bostonblackie
Received 0 Votes
True, the panels click together "thanks to our ingenious shape of tongue and groove" so says the literature.
Bostonblbackie
Bostonblbackie
bostonblackie; how to join the planks. the clips work end to end and long side to long side but not long side to end which would be the case in either layout. I do I go about connecting the planks?
Boy, you really confused me with that statement. I finally figured it out, I hope. One end and one edge have a tongue, the other end and edge have a groove. Which ever way you choose, it's the same concept. Hopefully the link I listed will work, it's a layout.
