How to close seams in Vinyl Flooring
I have a new vinyl floor in and would like to close the seams what should I use to seam the seals?
You did the work? They make...guess what...vinyl floor seam sealer! Check at any flooring company or even the big box stores. It's a clear liquid that you careful put over the seam and it bonds the two pieces.
vinyl floor
IVC Impact Sheet Vinyl Flooring Flagstone Terra 43 - 12' Wide Overall thickness of vinyl is 105 gauge
Super Guard urethane finish
Wearlayer thickness is 10 mil
Recommend full spread with releasable adhesive
39.37" x 39.37" pattern repeat
Loose lay only 225 sq ft or less
Mechanically embossed
12' nominal width
I tried the what the store recommended but it didn't work just looking for suggestions or other things people tried that worked for them
12' nominal width
