Removing 13 year old Viynl floor adhesive
Old 02-13-15, 04:00 PM
T
Received 2 Upvotes on 2 Posts
I am removing old Viynl flooring from my master bedroom, I have removed the actual Viynl tiles from the floor using a heat gun to separate the tiles from the adhesive but now I don't know how to get the adhesive itself off of the concrete. Has anyone dealt with this before and if so how did you remove it?
Old 02-13-15, 04:14 PM
chandler's Avatar
Received 11 Upvotes on 10 Posts
What type flooring are you going to replace it with? You are in Florida, so I am assuming it is on a slab, correct?
Old 02-13-15, 04:19 PM
Handyone's Avatar
To remove the adhesive, you can use a razor scraper. They come in varying widths and lengths. I like the shorter ones, it's a tough road either way.
Old 02-16-15, 11:59 AM
T
I plan on putting ceramic tile overtop of it and yes it is on a slab. The problem is that the previous home owners had about 5 Pomeranians living in that room which were "newspaper" trained. So basically the floor was disgusting and it has soaked into the adhesive underneath. That is the main reason I want to remove it.
Old 02-16-15, 12:09 PM
Received 1,290 Upvotes on 1,228 Posts
With the idea of ceramic going over this, solvents are out. You're left with hot water, a scraper and elbow grease.
