Can adhesive be thinned?
Old 10-23-18, 08:23 AM
I will be laying Tandus Centiva LVT planking on cement using Centi 6000 SP adhesive and the dry 'removable' method. I've done this before without issue. Here's the question. I have about 2 gallons of adhesive left in the bucket that has thickened up a little since the last install and it is proving to be a little difficult to spread with my trowel. . I really don't want to throw out a 1/2 bucket of adhesive just because it got a little thick. The adhesive is water based. So can I thin the adhesive with a little water?? Will that affect the performance of the adhesive? If I can't thin with water, can I thin it with something else, and what would that be?
I've tried contacting Tarkett and also Flooring International of America (makers of adhesive) with no replies.
I'm hoping someone here can help me out.
Thanks in advance for any advice.
Old 10-23-18, 01:36 PM
Received 1,166 Votes on 1,124 Posts
Just how old is it? If you thin it, I would stick with clean water but not much....
Old 10-23-18, 03:56 PM
Marq1's Avatar
Received 955 Votes on 867 Posts
Is it really worth risking a flooring issue over a 1/2 bucket of adhesive?
Old 10-23-18, 07:00 PM
Adhesive thinning
It's only about 3-4 months old. Not sure the bucket was sealed all that well. Marq1 makes an excellent point. It's probably not worth risking a flooring failure over a 1/2 bucket of glue.
Thanks for the info and the wake-up call.
JBNC1
