Sandpaper grit? - Vinyl Squares going over vinyl squares
Hello all - I am going to be putting vinyl squares over vinyl squares. I believe this will work. The existing floor is very solid mechanically, level and free of defects. I plan to off-set the new floor vs. the existing floor so that seams do not line up.
The existing floor has a bit of a texture (not extreme). So I plan to sand first to ensure a texture free surface. I'll be using a hand held orbital (not belt) sander. Its a small kitch floor, so the larger orbital sander ( ~ 5 x 9") seems to be the best equipment to use.
Does anyone has a suggestion on what grit of sandpaper I should use?
Any other ideas / pitfalls to avoid would be welcome.
Thanks.
Thanks.
