Odd hard bumps on vinyl floor
Old 05-02-21, 07:16 AM
R
Hi,
I have vinyl floor replaced in bathroom a few months ago as I had a leak from shower which had gone under old vinyl so needed to replace. The area was dried out and new plywood put down then new Lino place on top.
I have just gone to clean the floor properly and went under sink area and found a whole area that has loads of raised hard bumps on it. This is not a bump under the vinyl ( have the odd one of these) but on top and has a slight browny red colour. Will not clean off and not sure if can be scraped with Stanley knife as trying just with my nails its not budging!
Just wondered if anyone may know what this could be as I am clueless as to what these are and why they have appeared!
Thanks in advance
Rachael
Old 05-02-21, 07:37 AM
P
Received 1,575 Votes on 1,416 Posts
My guess would be chunks of dirt or nail heads underneath the vinyl telegraphing through. I have no idea what could grow in or on top of the vinyl to make the bumps. The color makes me think you might be seeing rust from the screw or nail causing the bump.
Old 05-02-21, 12:03 PM
sam floor's Avatar
Received 25 Votes on 20 Posts
If they installed 1/4" underlayment under the vinyl, which is the right way to do it, the floor under it may have been too soft and the nails could be coming loose. If they used something other than ring-shank nails or underlayment staples, they WILL come loose over time.
Old 08-05-21, 08:09 AM
B
Get a hammer and a soft clothe hammer it down
End of problem ................probably ring shank nails not set flush
Bumps on top ? maybe flaw in lino only thing it could be .send pic to shop where u bought it
Thats sounds like rust from maybe nails used from installer if its been a few months
again take a pic send to shop .....A bath they might blow u off .be persistent
