Adhesive
Old 05-26-21, 06:26 PM
Geochurchi's Avatar
Received 154 Votes on 140 Posts
Adhesive
Hi All, I laid down Home Decorator vinyl plank flooring, it looked good but I notice that some of the ends are lifting slightly, they will lay down with slight pressure, I plan on installing more of the same thing, I am wondering if it would be OK to apply a thin bead of adhesive on each end to prevent this from happening to the new install.
Geo 🇺🇸
Old 05-26-21, 06:28 PM
XSleeper's Avatar
Received 1,528 Votes on 1,372 Posts
Baseshoe is what would typically keep it down on the ends. Floating floors need to float.
Old 05-27-21, 04:30 AM
Geochurchi's Avatar
I should rephrase the question, adhesive for the end to end joints where they mate together.
Geo 🇺🇸
Old 05-27-21, 06:15 AM
XSleeper's Avatar
They should lock together on their own without adhesive. If you need adhesive you are doing something wrong.
joecaption voted this post useful.
Old 05-27-21, 02:30 PM
Received 125 Votes on 110 Posts
Did you use a hand floor roller to press down on the seams?
Old 08-04-21, 11:05 PM
B
Floating floor click ? NO GLUE........LVT u glue ? u did something wrong use a heat gun pull plank reglue...............glue has to set up .depends on product on wait time.......clear stick..........yeah roll with a hand roller.....watch trowel notch size on specs....don't lay it wet .you'll have a mess chasing glue in seams !!!
