I don’t want to use bullnose on the steps but….
Old 04-20-22, 08:21 PM
D
My runs are close to 13”. Flooring company says they don’t make a tread with that deep of a run and that I will need to use the flooring planks and bullnose to do my stairs. Please tell me other options! The pre-made tread looks so nice. I am approximately 1/2” too deep for the pre-made tread . 😡
Thank you
Old 04-20-22, 08:32 PM
XSleeper's Avatar
Received 1,977 Upvotes on 1,772 Posts
You posted in the vinyl and linoleum forum, so I don't know what kind of floor you are talking about. I'm assuming it's a wood floor?
Old 04-21-22, 07:24 AM
Marq1's Avatar
Received 1,211 Upvotes on 1,099 Posts
Don't know what your flooring material is but you could make your own treads from sheets of plywood/oak.
Old 04-21-22, 09:44 AM
Z
Received 436 Upvotes on 388 Posts
You could use a piece or 1/4-round at the back side of the tread to transition from the tread to the riser and cover that space.
2john02458 voted this post useful.
Old 04-21-22, 12:55 PM
D
I apologize. I am installing vinyl plank.
Old 04-21-22, 01:01 PM
XSleeper's Avatar
Do you currently have a nosing that could be cut off?
Old 04-21-22, 04:09 PM
D
Yes. The nose overhangs 3/4 of a inch. I was going to put a piece of 1x in there to use as the riser and to make it flush. (Will still be too deep for pre-made tread) Thoughts? They could also be cut flush but the current exposed riser is just ply.
current nose is just the edge of a 2x
Old 04-21-22, 08:43 PM
XSleeper's Avatar
Add a photo of the stairway if you can, and give us something to look at. I have one idea but would need to look at it first.
Old 04-23-22, 01:07 PM
D
Old 04-23-22, 01:27 PM
XSleeper's Avatar
Looks like adding 3/4 to each riser would eliminate your nosing and make them all 12".
Old 04-23-22, 06:46 PM
D
I thought the same thing but I called the flooring company again to double check. Their treads are 10.5” deep. I’m gonna be forced to have custom treads to stain or use flooring and bullnose I think.
Old 04-23-22, 07:17 PM
XSleeper's Avatar
Looks like your only reasonable option would be to remove all the treads and risers and make new stair jacks that have a standard tread size.
Old 04-23-22, 07:21 PM
D
And stringers? 🤦🏼‍♂️
Old 04-23-22, 07:49 PM
XSleeper's Avatar
That's another name for them.
Old 04-24-22, 08:03 AM
sam floor's Avatar
Received 39 Upvotes on 33 Posts
My concern would be how slick they will be with vinyl plank. Is this coming from and area where your feet.shoes might be wet?
