New bathroom flooring, install first or last?
Have a new built and installing "rigid core 12"x24" snap lock planks" in my bathroom, I believe it is vinyl. Can I install the flooring first then put my toilet and vanity on top? I hear pros and cons doing it both ways, some say install flooring first but don't screw the vanity to the floor, only to the wall, so the floor can expand and contract, some say never put a toilet and vanity on a floating floor, not sure which is the correct way...
The toilet goes on top of the flooring, the flooring should really go around the vanity but you can also set it on top. Flooring butts up to the tub or shower curb. I have never heard of anyone screwing a vanity to the floor. A bathroom is typically small enough that it won't cause any expansion / contraction problems when these items are on top. If the vanity was already in place you would go around it.
Only problem putting the vanity on top will cause is when you want to replace the floor someday. So that might be a reason to go around it.
marksr
voted this post useful.
Norm201
I have found that if replacing a bathroom floor, the chances are the cabinets will be replaced or taken out first then floor laid, and cabinet placed back in.
On all my bathroom remods, I have always brought the flooring right up to and flush as possible to the toilet flange. It always looks better if a flooring appears to go all the way under an object.
If I run my flooring around the toilet flange I'll be about a 1/4" lower than the flooring, should I put a extender spacer on the top of the toilet flange to raise it a little higher above the flooring?
On another note, do not caulk around the toilet after installation. I know it's not to code and not allowed in a public place. But at home, if you have a leak or failed wax seal, you want to know about it ASAP, before it ruins the subflooring.
Marksr, yes, I realize that. But a leak from the back side of a toilet is not always noticeable until perhaps several days s later. And if the floor is slightly unlevel, you may never see that leak until it's too late. Just how often to you actually look behind a toilet?
At home I have never caulked all around the toilet and it looks just fine. That might beg the question about dirt and mold forming under the toilet. Ordinary cleaning and housekeeping do not cause those problems. On the toilets that I've had to remove, the flooring was not dirty or moldy. Discolored, yes (actually it had the original color that was not faded).
But it's actually required by the International Plumbing Code to caulk a toilet to the floor.
With that said I still won't do it!
Last edited by XSleeper; 01-20-23 at 06:25 AM. Reason: No links to other diy sites
Sam, I don't disagree, but it's required in hospitals and public places. If you read the link I tried to provide (stupid rule) you'll see why it's required and why it's supposed to be done in residential homes also. Just do a GOOGLE search "Why is caulking a toilet required."
