Larger transition option?
Old 03-24-23, 05:37 PM
H
Received 2 Upvotes on 2 Posts
Miss calculated needed flooring and I am 2 pieces short but only need 2 inches of it. Id really hate to buy another $90 box for 2 slithers . does anyone know of a piece of floor trim or transition piece I can use here? 2 inches by 7 ft. Thanks
Old 03-25-23, 08:08 AM
2
Received 399 Upvotes on 348 Posts
A wider view photo showing the wall conditions would be helpful to see if some kind of trim could be used.
Where did you get the flooring? See if they may have a broken bundle or floor sample that you could get a couple of pieces from. Maybe a sample from the manufacturer. If the floor is floating, maybe you could move it to equalize the distance on both sides and use trim smaller than 2 inches on both sides.
Old 03-25-23, 10:50 AM
XSleeper's Avatar
Received 1,975 Upvotes on 1,771 Posts
I'd say bite the bullet and buy a box, which you would have had in the first place. Anything else will look pretty shabby.
