Go Back  DoItYourself.com Community Forums > Interior Flooring, Floor Coverings and Coatings Center > Vinyl and Linoleum Flooring
Reload this Page >
Can I place vinyl sheet floor on top of tile instead of hardwood floor?
Old 11-29-23, 08:28 PM
Z
Received 5 Upvotes on 4 Posts
Hello,
I have about 400 sq ft of kitchen floor that looks like the attached picture. But my wife said it's hard to clean and maintain. I am thinking about using the following vinyl floor roll to cover up the tiles. But not sure if it's doable or not. Because the tiles are not 100% flat and the vinyl may not be able to stick the tiles properly.
https://www.amazon.com/Oxdigi-Floori...54&sr=8-6&th=1
Any recommended solutions are welcome. Please let me know if more info needed.
Thanks in advance.
John Z
Old 11-29-23, 08:40 PM
XSleeper's Avatar
Received 1,973 Upvotes on 1,770 Posts
I sure wouldn't do it in my house.
z_johnq voted this post useful.
Old 11-30-23, 08:21 AM
sam floor's Avatar
Received 38 Upvotes on 32 Posts
I have done it for customers. Just don't expect it to look pretty.
Old 12-04-23, 06:41 PM
Z
I thought so too! Any recommendations? I can remove the existing tiles and replace with square or rectangle large size of the tiles, which should be much easier to clean. But how can I make the floor flat? I did it for one of the bathrooms, a small one, and I don't like it much It's like 20, 25 sq ft in size. Let alone the kitchen, which is much bigger.
Thanks.
Old 12-04-23, 06:54 PM
XSleeper's Avatar
You could put LVP / LVT over the tile floor if it is flat enough. The small voids that would show through a thin sheet of vinyl likely wouldn't be a problem for the LVP / LVT. The mfg has specs for how flat the floor needs to be when checked with a straight edge. Most LVP / LVT will have its own underlayment attached to it making it a snap to install. You'd likely want something waterproof. And if you gave a dishwasher you'd want to ensure that it will still fit if you put flooring all the way under it. Most are adjustable up to a point.
