How to safely glue rubber sheet in closed environment
Old 05-21-24, 04:34 AM
E
Question How to safely glue rubber sheet in closed environment
Hi everyone, i would like to glue a Rubber sheet 1.50x0.75m (cut to size) on top of an ikea desk to use it as a workbench, since this is located in my office room, is there any safe glue (that doesnt release solvents) that i can use so i dont have to move the desk outside?
Old 05-21-24, 04:37 AM
XSleeper's Avatar
Received 1,960 Upvotes on 1,757 Posts
Non-flammable contact cement is low voc. Follow label directions. Any cove base adhesive would also work if you have a notch trowel to spread it..
Old 05-21-24, 05:04 AM
E
Thanks, just did a search online, looks like i will have a hard time finding this in my country, i will keep searching but do i have any other options?
https://www.mrbricolage.com.cy/evost...-adhesive.html
this one says low odour but still flammable
Old 05-21-24, 05:15 AM
XSleeper's Avatar
Low odor is probably what you need.
Old 05-21-24, 07:07 AM
P
Received 2,270 Upvotes on 2,022 Posts
Do you have to glue it? Is it thick enough to lay flat on it's own and stay in place without gluing?
Old 05-21-24, 08:19 AM
Received 1,280 Upvotes on 1,218 Posts
Not sure what you have in mind but rubber is not the surface I want for a workbench.
Old 05-21-24, 01:08 PM
sam floor's Avatar
Received 38 Upvotes on 32 Posts
Just make sure that the adhesive is made for rubber or it won't hold.
