Laminated flooring over Linoleum
Can I install a laminated flooring on top of an existing linoleum in my kitchen/nook?
I've seen it done. Your existing floor will give you the best answer.
Is it peeling up any where? If so, it is for a reason, and you dont want your new floor coming up for the same ones. It has to be all the same level you don't want potential "mud puddles" on your new floor. IT NEEDS TO BE CLEAN CLEAN CLEAN AND CLEANER Dirt is the antiadhesive.
Good Luck
Good Luck
