vinly floor
Old 05-22-02, 06:40 AM
cook1
vinly floor
How do you remove old sheet vinly from sub-floor???
Old 05-22-02, 03:29 PM
T
Removing vinyl from subfloor
A heat gun, scraper, and lots of patience is usually required to remove vinyl. If the vinyl was installed prior to the 1980s, there is a good possibility that the vinyl and the black adhesive contain asbestos. If this is the case, then the floor should be encapsulated with a new underlayment material if you are installing new vinyl.
http://www.doityourself.com/home-safety/asbestos.htm
